Sportsman Throttle cable end piece
I have a 98 sportsman 500 and have lost the small end piece that holds/connects the throttle cable to the carb butterfly.
Its the larger brass looking part that hold the small cable end. anyone know where I can pick one up or another option. I guess a universal cable will have the larger end. just thought I'd check if these pieces were sold or not. thanks |
just found one.. everyone wants 17 for that puppy.. anyone know of a replacement cable that would get around not having that piece.
http://www.partzilla.com/parts/detai...P-3130543.html |
You can find then for 12 bucks on ebay,but shipping is around 6 bucks.Either way an expensive piece of brass. Easy little part to slip out of your hands as I've dropped a few over the years.
thanks,
I searched far and wide for them.. I finally broke down and got one.. was hoping there was a cheaper alternative. guess i could make one.. but I guess my time is worth a little. :) I thought about using a small screw, but that might cut the cable and break while riding.. |
On the throttle cable guide I wouldn't take chances with a home made part. Remember to adjust the throttle cable to where you only have 1/8" slack at the thumb lever so the etc contacts won't touch.
