need help finding a part!!!????!!!
Old Jul 18, 2017 | 06:24 PM
95scramblerruben1033's Avatar
Default need help finding a part!!!????!!!
yes and hello to all of my fellow atv'ers u see i am really needing this part number right it is the bracket that you hook up the solenoid to 1995 Polaris SCRAMBLER 4X4 (W957840) Magneto Assembly Scrambler | Babbitts Polaris Partshouse it would be the back part of number sixteen or what number sixteen bolts to. im not exactly sure what happened but mine fell off and i cant find it anywhere. so any help in the right direction would be greatly appreciated.
THANKS IN ADVANCE
RUBEN
Old Jul 19, 2017 | 01:58 PM
Never had one to do that,but... The bracket is spot welded on to the body. If all else fails they are cheap. Just depends on where you're located.
Amazon Amazon
Old Jul 19, 2017 | 05:11 PM
thanks OPT but mine wasnt spot welded it was bolted on to the actual solenoid.so the bracket and the solenoid acted like a sort of clamp and it would clamp on to the body.
THANKS
RUBEN
Old Jul 20, 2017 | 05:13 AM
I wouldn't break a sweat about the bracket. Spend the 5 bucks for a new solenoid.
Old Jul 20, 2017 | 09:40 AM
NO BUT THE SOLENOID IS FINE. I just am needing the bracket to put into place and ground it to the body as it needs to be.
THANKS
RUBEN
Old Jul 20, 2017 | 01:41 PM
Then you can make one or buy a saddle clamp that will fit the solenoid body. Any good hardware store should have different sizes of them.
Attached Thumbnails need help finding a part!!!????!!!-48mm-85mm-saddle-font-b-clamp-b-font-rubber-lined-hose-font-b-clamp-b-font.jpg
Old Jul 20, 2017 | 03:35 PM
great thanks OPT.
RUBEN
