help. quit starting
Wish you luck on the Caltric stator. If you lose spark again,the Ducati cdi/coil packs were also bad about failing,but you can still get those for some strange reason from Polaris.I went back and forth on replacing stators and coil packs until one day the stator part number changed to the new Kokusan kit and did away with the Ducati system entirely. Again good luck on this replacement stator.
