Stock main jet on a scrambler 400l?
Old 03-08-2017, 02:16 PM
KingCobra's Avatar
Default Stock main jet on a scrambler 400l?
So i just found out that my scrambler 400l needs a full rebuild (top & bottom). and would like to know what main jet i should use for a STOCK scrambler? and also if it would be bad if i used power reeds with a STOCK main jet?
Any feedback would be appreciated.
Old 03-08-2017, 04:06 PM
DirtDevil101's Avatar
I think the stocker is a 230...but many drop that down to 220 as they are jetted fat from the factory. Reeds kinda act like a performance cam on a thumper...in that they are quicker to react to the engine pulse thus allowing both more fuel & air to enter the crankcase (cams have longer duration & lift kinda doing the same thing)...generally no jetting required...but every machine is different so learn to read your plug!!
Old 03-08-2017, 04:08 PM
Jetting changed a little over the years,would help to know the model.For instance a 1996 Scrambler 400 had a 250 main,35 pilot jet.1998 model used a 230 main,35 pilot jet as stock.
Old 03-08-2017, 04:15 PM
KingCobra's Avatar
Mine is a 98 2X4.
Old 03-08-2017, 04:16 PM
KingCobra's Avatar
oh, duh! it shows it. thank you.
Old 03-08-2017, 04:17 PM
KingCobra's Avatar
ok, thank you for the response.
Old 04-18-2018, 01:36 AM
Eyeballsdeep's Avatar
yah, this 96 scrambler 4x4 has 250 main.
