Rear hub play
Old Jun 12, 2018 | 08:25 PM
gfyracing's Avatar
Default Rear hub play
I have a 1994 Polaris 300 2x4 and on the weekend the right rear hub stripped. I found the axle nut loose and a washer missing. I have a used hub but when i put it on there is some rotational slop on the splines. If i have the hub spaced out a bit there is less slop. Is it alright to put a washer behind the hub to move it out a bit?
Old Jun 13, 2018 | 02:46 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just my .02 and I know a pain but your going to be better to replace it as the good part of the spine most likely will not last even if you move it out to it.
Rahmelo Malik
Trick and Stunt Riding Photos
Oct 28, 2015 09:29 AM
cbhunting
Jul 5, 2010 10:39 AM
jackass650
Oct 26, 2004 11:51 PM
bigdawg1031
Mar 31, 2002 02:39 PM
