belt deflection question
Old Apr 22, 2001 | 01:19 AM
soggyrider's Avatar
I was checking the belt deflection on the Magnum today and noticed I have 1&7/16 inches of deflection when I should be at 1&1/8 inches. My question is, do you add or remove shims inbetween the sheeves to increase tension? And how much does one shim change your tension?
Yes the belt is the right length @40 inches and also the right width.
Old Apr 23, 2001 | 08:06 AM
famosrichit's Avatar
Removing shims will tighten the belt. I have no idea how much removing one shim will tighten the belt. Hope this helps
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
Logan Collins
Sep 5, 2015 08:03 PM
