Polaris 425 magnum 6x6 ???
Old Jul 22, 2018 | 08:55 AM
Larry1948's Avatar
Default Polaris 425 magnum 6x6 ???
my 6x6 flutters at idle ,but runs great after throttle.And LOVES gas.. a little to much.A time it dont shut off with switch.(checked all grounds).New air,and fuel filters..Any suggestions?
Old Jul 23, 2018 | 03:57 PM
jstjoehere's Avatar
Werent those carbeurated? Fluttering at idle im guessing it either raises or drops rpms while idling? Check your carb mounting gaskets and boots. May be time to rebuild the carb. Usually vacuum leakage causes this. Probly runs fine at higher rpm when air is being pulled through faster. If theres no signs of the above a quick compression test wouldnt hurt... As far as not shutting off sometimes you said your grounds are good so id check the switch to make sure its grounding when switched to off. If so start checking that wire from the switch. Look for a pinched or rubbed place possibly even just a stretched place in the wiring.
nuttymomsix
Sep 13, 2011 08:17 PM
Stose
Nov 6, 2008 06:43 PM
kschas
Sep 15, 2005 10:59 PM
muddymagnum
Oct 22, 2003 11:48 PM
Loyal
May 12, 2000 09:19 AM
