2000 Polaris Sportsman 500 AWD Problem
Old Apr 2, 2019 | 09:34 AM
TFCO's Avatar
Default 2000 Polaris Sportsman 500 AWD Problem
Hello All,
A friend and I are in the middle of repairing my AWD on my ATV... I was told by someone to ground the two brown wires going to the speedometer six wire harness (splice into them and ground each one the out). Has anyone done this fix??? Right now i'm only getting power at one end of the harness the goes to the hub coil and not the other. When we join the the hub that does not have power to the other that does the AWD works. Right now my switch does not work but if we manually push the two contacts together in the switch the AWD works but with the switch it does not.. One harness going to the hub coil works and absolutely no power on the other going to the hub.
Thanks for your help!
Old Apr 2, 2019 | 02:58 PM
850 trailrider's Avatar
You have to cut/splice both the left and right front hub coil brown wires twist together and hook to pigtail to new ground point to ground on frame easiest to do near ignition coil. Both hub coils plug into harness near that point
Old Apr 2, 2019 | 04:53 PM
TFCO's Avatar
Thanks we tried doing that but couldn’t get it to work. The only way we can get it to work is discribed above other than splicing into the brown wires in the speedometer.
Old Apr 11, 2019 | 08:46 AM
TFCO's Avatar
Found out the switch for the AWD was no good after replacing it and some bad/missing wiring we got the machine back up and running.
Old Apr 11, 2019 | 09:29 AM
Glad u got it fixed ! glad u let us know what the fix was. Some people never post if or what they got it fixed, it might help others in similar situation
Old Apr 11, 2019 | 09:34 AM
TFCO's Avatar
Absolutely I hope it will help others!
Old Apr 11, 2019 | 05:10 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
adamrhymer101
May 10, 2021 12:54 PM
trbojet1
Oct 12, 2017 04:33 PM
02sptsmn500ho
Apr 13, 2008 10:33 AM
4wheelinfun
Apr 1, 2003 03:20 PM
