1999 Polaris TrailBlazer
I have a 1999 Polaris TrailBlazer that wont start, I put in a new battery about 2 months ago because I thought that was the problem, it started good for a few weeks and then nothing? Hoping ths can be a easy fix.
check for spark, if spark does the carb need to be cleaned is it getting gas. if it has some hrs on it you might also wnat to do a compression test to make sure it has min. of 100 psi compression.
