98 Sportsman Rear Brakes
the rear foot brake on the older sportsmans did not work very good. you have to bleed the hell out of them. a trick we used to use if it was working at all was to place a heavy weight on the foot pedal for a good length of time to help build pressure up in the small and some times useless cylinder. make sure there is plenty of brake fluid in the revivor.
