2003 Polaris Sportsman 500 HO no spark. HELP!!!
Old Apr 13, 2021 | 01:57 PM
David Ledger's Avatar
Default 2003 Polaris Sportsman 500 HO no spark. HELP!!!
Hey everyone, Im new to small engines. I have a 2003 Polaris Sportsman 500 HO that I bought and wouldnt start. The previous owner put a new Carb in it because they said it was run and then die. Looks like they poked around at wires in the front also.
So I put a new Coil in it and a new on off switch on the bars. It would start then die after 10 min. then had to wait an hr to start again for it to die after a few min. I put a pickup coil in without checking the old one. The new amazon one tests at 110 ohm and the stock original tested at 90 ohm. I get nothing now when trying to start it.
I tested the Stator and dont get any ohm reading from it at all. Does the stator stop it from giving spark? I was thinking about also changing out the CDI but dont know how to test if it is good or not.
Can someone help me??
Thank you in advance.
cookiemike
Aug 17, 2014 05:30 PM
2161peters
Mar 4, 2013 06:17 AM
ewok_89
Jan 4, 2009 06:57 PM
mr1340
Technical and How-To Articles
Sep 28, 2008 09:34 AM
johnsteph515
Sep 9, 2005 02:07 PM
