Knocking Noise
Old May 15, 2001 | 08:33 AM
Beefy250's Avatar
Has anyone heard of or had a problem with the TB 250 jug shaking or vibrating so bad at idle that it hits the shifter linkage. I've only noticed it in reverse before applying the throttle. I'm sure this isn't normal, I know that the engine is mounted with rubber bushings to allow for vibration but this didn't start until just recently. Help????????? The bike is only 4 months old and still under warranty, 24 months worth but my dealer is 127 miles away. I guess I should find another dealer. Beefy250
Old May 15, 2001 | 08:38 PM
NewDSLover's Avatar
Check you base & head bolts, check your lower & upper engine mounting bolts for tightness. Since it's a new unit, bolts can come loose. Good Luck.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
