Noises on scrambler
I'm sorry if this has already been discussed, but why does the belt pulley/clutch rub on the cover (near the floorboard) when these machines get older (96 500) As soon as you hit the gas, the noise goes away.
I HAD THE SAME PROBLEM WITH MY 97 SCRAMBLER 500. I TOOK IT IN AND WAS TOLD THAT THEY ADDED SPACERS BETWEET THE COVER AND THE BELT. OF COURSE I HAD TO BUY A NEW COVER. JUST A NOTE I THINK THAT THEY USED A RUBER BUSHING ALONG THE BOTTOM.
i HAVE HEARD IT ONCE SINCE THIS WAS DONE. i WAS JUMPING AND LANDED HARD, BUT THE NOISE WENT AWAY AND HASN'T BEEN BACK
I have just encountered this problem recently and devised a solution. I cut a big piece of thin ( 1/8 inch ) plastic into 2 inch by 1 inch squares. I started stuffing them between the PVT back cover and the frame ( located near the PVT vent outlet ) until the noise dissapeared. I then glued the plastic pieces together ( like a stack ) and glued some rubber to one side ( to prevent rattling from the frame ). I then cleaned the PVT back cover with simple green or spray nine to remove the crud then mineral spirits to remove any remaining grease. I finally glued the stack to the back of the rear PVT cover. The noise hasn't been back since and my PVT cover is fine.
Chris Piccciotto
99 Scrambler 500
Chris Piccciotto
99 Scrambler 500
exmotocrosser
Sep 13, 2019 06:12 AM
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
