"ATTN" 39 pwk owners
Old Nov 28, 2004 | 05:43 PM
  #21
braveops's Avatar
Default "ATTN" 39 pwk owners
that was on mine yours could be diffrent cause of the temp like right now it is 3 celsus leave your pilot for now but if you change the main and it get so it does not run right then turn it in or out do you have a 170 main with u ?
Old Nov 28, 2004 | 05:49 PM
  #22
braveops's Avatar
you main will affect everything pilot i think is up to 1/8 throttle needle is above 1/8 to half or 3/4 the way you describe it sounds to rich
Old Nov 28, 2004 | 05:52 PM
  #23
Troyer23J's Avatar
Yeah, i put a 170 main in, but didnt run it yet. I know its lean, but i havent done this before and wanted to talk to someone first, to be sure i wasn't gonna go too lean.
Old Nov 28, 2004 | 05:59 PM
  #24
braveops's Avatar
if it garbles or stumbles it is usally to rich like when you flick the choke on you realy notice it now if it bogs out of the hole when u pin it turn pilot in a little
Old Nov 28, 2004 | 06:02 PM
  #25
braveops's Avatar
did you find that pin? did you pull it out?
Old Nov 28, 2004 | 07:44 PM
  #26
Troyer23J's Avatar
Mine doesnt have the pin.
New problem though. I put in the 170, adjusted the air screw some. Left in the 38.
Put in a new plug too. I go to start it and i can hardly pull it to start it. I pulled the plug out and it pulls like it should without it in, put it in, and i can't pull it. not good....
Old Nov 28, 2004 | 08:17 PM
  #27
EAB's Avatar
EAB
It wont pull over with the new plug? Its not too long is it, sticking down into the combustion area?
Old Nov 28, 2004 | 08:18 PM
  #28
Troyer23J's Avatar
Its the same kind of plug that was in it. BR8ES
Old Nov 28, 2004 | 08:25 PM
  #29
tbsleeper's Avatar
run an iridium plug it actually gives it better starting it seems like to me and gives it a better spark i dont no why...and wats ur gap at??
Old Nov 28, 2004 | 08:27 PM
  #30
Whitedog's Avatar
Wont pull over at all?
