Problems with new 500 HO Help
Old Jun 25, 2001 | 03:16 PM
jimmy50's Avatar
I have a new 500 HO and was out this weekend and had the speedo pegged at 60mpr. After running wide open for about 60 seconds the throttle started to cut out. I let off the trottle for awhile and running at 60 mph again and it did the same thing. any suggestions??
Old Jun 25, 2001 | 03:24 PM
MagnumMudMan's Avatar
jimmy
I am going to make an educated guess. It is probably the ETC (electronic throttle control). The ETC is designed to cut out the machine in the event of a stuck throttle. I do not know how to adjust it, but as your machine is still under warranty, I would take it back and have them adjust it for you. Hope this helps.
Old Jun 25, 2001 | 05:46 PM
jimmy50's Avatar
Thanks for the information on the ETC control. The only problem is that my machine is out of warranty so I have to figure this one out myself or pay the big bucks. Anybody know how to adjust the ETC control?
Old Jun 25, 2001 | 05:54 PM
jimmy
Now is the time to seriously consider buying the service manual for your machine. They costs between $45-$55 dollars and you can get them from your dealer. The way I look at it, if it saves me at least one hour of labor at the dealer, then it paid for itself. Anyhow, you will feel more comfortable working on the machine knowing that you have the correct information.
Old Jun 25, 2001 | 06:00 PM
Thor's Avatar
My dealer sells them for $29.95 plus shipping. Call 952-884-2111
and ask for Lindsey.
Old Jun 25, 2001 | 06:19 PM
kukerdan's Avatar
OR
you could just not peg your throttle,
when your fliyng it, rev it betwenn 3/4 and full, youll keep your speed, and it wont cut off
Old Jun 25, 2001 | 06:35 PM
jimmy50's Avatar
If I go back down to 3/4 throttle and back to full throttle sometimes it would work ok. We had been running about 2 hours into the day and the temp was hot out. I have changed the fuel filter, spark plug, and all fluids. I was surprised the plug came out pretty black.
Old Jun 25, 2001 | 07:40 PM
kukerdan's Avatar
that could be your problem then,
on my rokon i was going full throttle, and then it cut back and died
Old Jun 26, 2001 | 10:15 AM
jimmy50's Avatar
Thor thanks for the tip on the manual I picked it up last night for $30.00.
Hennin Manson wanted $45.00.
Old Jun 26, 2001 | 10:21 AM
Thor's Avatar
<< Thor thanks for the tip on the manual I picked it up last night for $30.00.
You're welcome
