how do you tighten chain
Old Jan 29, 2000 | 06:58 PM
whisky's Avatar
i lost my manual and me chain needs tightined on my scrambler its the concetric drive model. would you please help.
500 scrambler with mods
Old Jan 29, 2000 | 07:12 PM
mudmachine's Avatar
Loosen the two bolts on the rear of the swingarm, and I believe there are two bolts on the brake assembly... after that, put a screwdriver thru the hole in the sprocket hub until it engages the Axle carrier.... roll the quad forward to tighten, backwards to loosen.... Retighten bolts to the specified torque...
I would suggest removing the two axle carrier bolts entirely and cleaning the threads out on a wire wheel... You might coat the threads with a THIN coat of anti-seize....
Good Luck....
Old Jan 29, 2000 | 07:42 PM
quad_man's Avatar
The reccamended torque settings on the brake & carrier aren't critical, but I reccamend following them. Until I stuck a torque wrench on it, I found out I was over tightening the brake bolts and under tightening the carrier bolts, this explained the chain loosening. Now no more loosening.
You can e-mail Polaris and they will send you a book for free.
Old Jan 29, 2000 | 08:16 PM
whisky's Avatar
whats there email address. thanks alots
what hole you talkin about in the sporket.
Old Jan 29, 2000 | 11:44 PM
clindst's Avatar
here is there email, go to the bottom of this page and you will see the email icon........
http://www.polarisindustries.com/email.cfm?PAGE=EMAIL
Hope this helps
Chris
Old Jul 16, 2003 | 06:18 PM
Amygirl's Avatar
Default how do you tighten chain
Do you know how to tighten the chain on a trail boss 325 2001 model?
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
