bolt pattern for my scrambler fronts
Old Aug 23, 2001 | 09:19 PM
kukerdan's Avatar
i need to order new rims,
what is the polt pattern for my 95 sc400 4x4,
i would really appreachiate it
Old Aug 23, 2001 | 09:27 PM
kukerdan's Avatar
also....
what rims should i use,
i am putting 25x8x10 (or 12)
on the front, since they dont make 7 inch wide 25 inch tires that are for a 4x4,
i was thinking dirt devils,
oh yeah,
and can i put a 8 inch wide tire on a 7 inch wide rim?
that would help a little,
please tell me what i should do
Old Aug 23, 2001 | 11:17 PM
AZ400L's Avatar
Your bolt pattern is the same as a Banshee, but why do you think you need 25" fronts?
Old Aug 23, 2001 | 11:53 PM
kukerdan's Avatar
well,
because i have 25 inch rears,
i need to balance out the gear ratio bettwe than 23:25
25:25 is near perfection
Old Aug 24, 2001 | 08:01 AM
MaineRider's Avatar
Kukerdan. The bolt pattern on my 2000 Sc and 96 Sport are both 4x4 on the front and 4x156 on the rear. If you order from a reputable company they will make sure you get the right rim just tell them what it is going on. And yes you can put a wider tire on your rims. I recommend at least 2"
wider on the front. It helps keep your rims from getting all bent up.
Old Aug 24, 2001 | 01:05 PM
Todd400's Avatar
Actually Mainerider has it swaped, The fronts are metric at 4 on 156 and the rears are standard at 4 on 4, I have 8 inch dirt devils on my fronts with 10x5 rims and there is no problem, Check out my pics and you can see they look pretty sweet[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 25, 2001 | 10:17 PM
kukerdan's Avatar
nice ,
so i will have plenty of room with 8 inch wide tires,
10x5 rims sound goo,d , what about 10x6 or 12x6?
and i have 40$ to spend on my quad (my parents are buying me the tires and rims for my b-day [img]i/expressions/face-icon-small-smile.gif[/img] )
look at the mods i already have and tell me what i should spend my money on, i already go plenty fast, i pinned it on the road today because my freinds broken thumb was hurting, (its his throttle thumb, feel for him [img]i/expressions/face-icon-small-sad.gif[/img] ) i pulled away from his bayou 220 so fast i didnt pin it for long, but the speed flattened my chest , i would have got a few more mph if i ducted down from the wind,
anyway i need for power,
maybe professinal reeds? green spring? what?
i run 92-94 oct. gas
Old Aug 26, 2001 | 03:18 AM
Todd400's Avatar
When I ordered my Douglas rims the 10x5 were the only ones with the correct offset, It might be different now im not sure, Ive seen a couple Scrams with 12" rims and they didnt look too appealing to me, I think the 10x5's will be pretty close to cover all your base's The 10x6 rims I think might not clear your hub unless they offer a different offset now. With 40 bones I would get a HPD steering bushing to compliment your new tires, If your Scram has its original you will be surprised at the results the billet one delivers for $30
Old Aug 27, 2001 | 06:32 PM
kukerdan's Avatar
sounds good to me,
but what 25 inch tire do they offer with 10 x 7 ?
(you mentioned at least 2 inches bigger to protect the rims?)
i want dirt devils, 589's , bear claws, or somthing similar
Old Aug 28, 2001 | 07:23 PM
Thor's Avatar
Try these
