scrambler 400 case reed clearance?
does anyone known the connecting rod clearance for the 400
2-stroke? i need the rod measures and all needed infos about this area,does the counter balance weight to the crank?
are they any aftermarket counter balance?thanks a lot!
o k,let take a look more closely,does anyone known the distance between the stock rod to the case of the scrambler 400 2-stroke motor?
while the case is spliting,i need the distance info between the stock rod WHILE it is on the crank to the case...thanks.
exmotocrosser
Sep 13, 2019 06:12 AM
