Loose Chain!!
Old Sep 30, 2001 | 08:14 PM
500SCR's Avatar
Ok guys and gals, I need your help. I have a 99 Scrambler 500 4x4 that insist on running with a loose chain. I am constantly adjusting a tightening this chain. On a 5 hour ride today, I had to adjust and tighten it twice. Is this a common thing for these or am I doing something wrong? The chain is in good shape as well as the sprockets. I follow the manual when I do this and I am torquing the bolts to 60ft lbs.
HELP!!!!
Scott [img]i/expressions/face-icon-small-sad.gif[/img]
Old Sep 30, 2001 | 10:41 PM
500SCR's Avatar
Come on guys and gals, I need your help!!
Thanks
Scott
Old Sep 30, 2001 | 10:55 PM
RacerX's Avatar
I have a 99 SC500 also but have never had a problem keeping the chain tight. I believe there are four bolts that need to remain tight. The two that clamp around teh axel housing that are visible from the rear and the two that hold teh upper and lower caliper mount in place. If there are all tight, is it possible that you may have gotten grease or some other lubricant on these clamping points that is allowing them slip?
Just some thoughts
odonnks@aol.com
Old Sep 30, 2001 | 10:59 PM
500SCR's Avatar
Thanks RacerX, I haven't thought about checking it for grease at the clamping points. I do tighten all four bolts and it still loosens up. I'm going to take it all apart tomorrow and check everything to see if I can find the problem.
Thanks
Scott
Old Sep 30, 2001 | 11:22 PM
modquad's Avatar
The brake caliper bolts should get a drop of blue loctite, and be torqued to 18 ft/lbs. The carrier bolts get torqued around 40ft/lbs. Good post on the possibility of lubricant getting in there. Also, HPD now offers a chain tensioner for concentric models. 763-389-3336
KT
Old Oct 1, 2001 | 07:43 AM
500SCR's Avatar
Thanks guys, I will check into the tensioner today.
Scott
Old Oct 1, 2001 | 11:18 AM
imported_sixty9cobra's Avatar
My sons trailboss was like that, I fanally replaced the chain and have not adjusted it in 3 months. I bought the chain from the dealer 69 dollars they must be using a better quality chain is my only guess. I can relate to what you are saying about adjusting it all the time. Try a new one is all I can suggest.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
bmark0610
Sep 7, 2015 09:42 PM
