Direct Hit Ignition System 4 my 325
the direct hits high power spark amplifier kit WILL work on any engines/motors you can think of,it simply boost your ignition spark system by 500x so more power and quicker response.
it give the hard ignition discharge of a better ignition system just by adding a spark amplifier on your spark plug,
complete satisfaction or money back guarantee.
Theres just too little detail/technical description for me! As it stands, it looks like somethin JC Whitney would have in their catalog along with the "tornado" air swirler gizmos.
Sorry for being so skeptical...
What about the guy at the car shows selling the spark amplifiers for $19.95 or whatever where he pulls wires WITH it installed and engine keeps running, but runs like crap w/o etc etc.
That's what this reminds me of.
Slick 50, Duralube, Fitch fuel catalyst, K&N filters, healing magnets, KM (Matol) and the snake oil salesmen from the old west. Birds of a feather...
You know, those tornados were good dirt traps! You see, they get oiled from the K&N and the dirt that passes through the filter (like a SIEVE) would "tack" on the metal.
Whoa whoa whoooooooaaaaaaa, Dieselpro, the K/N is LEGIT. No it wont make cars or ATVs do wheelies, but it does improve airflow. Which in turn improves power. Air makes power. Just the filter alone can improve, but in some cases the air delivery system is so suffocating, until its improved, nothing will help it.This is NOT a personal attack Dieselpro. Im skeptical of the Direct Hit system, its so simple, but if it works what a deal. MSD,Accel, Mallory look out!
PD
PD
I have a Direct Hits kit on the way. I'll post my findings. For $31.50; it's a deal. I'll second the K&N promo. I run one on the Dodge as well.
Install a K&N along w/ a helix/throttle body spacer, and you too can scramble the eggs in the shells. Another avenue is the new line of Holley mesh gauze filters. They claim better flow due to more accurate application of the rubber sealing material.
KT
KT
In time you will all learn that the marketing hype behind the K&N is pure BS. YES it does flow air, but at the expense of filtration.
I'm told Cummins has recently invoked a special warranty policy stating engine failure warranties are to be denied if using a K&N filter. Ive seen no written proof of this.
I'm NOT trying to BS anybody here. Simply put, if you were to put a secondary filter on or smear some dielectric grease inside the filter, you WILL see a large amount of grit accumulate.
I burned my K&N filters...
