Clutch springs
Old Jan 25, 2002 | 12:47 AM
67bullet's Avatar
Can someone explain the procedure for installing the secondary clutch spring. Do you just compress the spring and install the snap ring or do you preload the spring by twisting it?
Old Jan 25, 2002 | 12:55 AM
Quadfather's Avatar
I believe you turn it 1/3 to preload it. But I'm probably wrong, as usual. I remember changing mine, and preloading it.
Old Jan 25, 2002 | 02:49 AM
stinky's Avatar
Yes you are correct quadfather,
Did mine today, 1/3 turn worked for me..
Old Jan 25, 2002 | 07:45 AM
67bullet's Avatar
Don't want to sound stupid BUT, which way did you preload it, clock wise or counter clock wise?
Old Jan 25, 2002 | 09:46 AM
walexa's Avatar
67bullet,
Load it to where you are winding the spring tighter, not opening it up. I'm not sure which direction this is, but if you look at it, you can figure it out. If you preload it the wrong way, you will know..........your bike will rev high and barely move, like a slipping clutch on a manual machine. Once you put it on the bike, take it for a quick spin before you put the cover back on.......just to make sure you got it right.
Waylan
Old Jan 25, 2002 | 10:28 AM
Farmr123's Avatar
If I had to guess off the top of my head, I would say counter-clockwise.
Old Jan 25, 2002 | 12:15 PM
elroy's Avatar
Without having one in my hand to see, I can't remember for sure.
Old Jan 25, 2002 | 03:14 PM
stinky's Avatar
67 Bullet,
Push helix down about 1" onto the spline & hold it there.
A friend is needed for this part<<<
While holding the helix, with your free hand hold the outer sheeve.
Get your mate to spin the inner sheeve 1/3 turn counter clockwise
Slide helix down shaft.
Install snap ring...Done
Old Jan 25, 2002 | 03:31 PM
gregsims's Avatar
Unless you have EBS.
Old Jan 25, 2002 | 03:50 PM
BigDog400's Avatar
You are right But if you have a small weight scale like a fish scale you would get from Wal-Mart for 9.99 Hold the front side and use the scale and hook in a hole in rear and pull it, it should start moving (rotation) at 12lbs, if it does then your spring is preloaded right any less or any more its not right.
