chain tension is inconsistant.....why?
Old Jan 27, 2002 | 12:08 AM
ScramberShadow's Avatar
I was tightening my chain up and noticed that when i got it where i wanted it and then spun the wheels around that it would get tight and then loose. I checked all the teeth on both sprockets and they look fine. I can t see anything that would be causing this. any answers would be helpful....thanks in advanced.
Old Jan 27, 2002 | 01:13 AM
OffRder15's Avatar
It is normal for a chain to have a tight spot, but not drastically tighter.
Old Jan 27, 2002 | 03:02 AM
boneylong's Avatar
ride it a little to get chain warm//then oil it with good chain lube..that should end your troubles!!
Old Jan 27, 2002 | 11:35 AM
xploridaho's Avatar
The same thing was happening with mine, turns out the bearing in the consentric where bad. Changed them and no more problems.
Old Jan 27, 2002 | 12:18 PM
waynaferd's Avatar
That happened to my old TBlazer, and the dealer said it just had a tight spot in it, and to check chain tension on the tight spot when adjusting the chain, because it was worse to have the chain too tight then too loose......Latah.......
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
raman8tor
Sep 20, 2015 07:35 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
