ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   Where'd my throttle response go? (https://atvconnection.com/forums/polaris/55998-whered-my-throttle-response-go.html)
AdamScramblr400 Jan 29, 2002 08:11 PM
I was out doing wheelies yesterday, and noticed when I floor the throtle, It bogs down, and has like no throttle response. I was thinking maybe a torn reed? I pulled the pull start, and still have all my compression, as far as I can tell. I used to have great response. Any ideas?
ftwflh Jan 29, 2002 08:17 PM
Did you try cleaning your air filter?
AdamScramblr400 Jan 29, 2002 08:25 PM
Yeah, but I'll try again
ftwflh Jan 29, 2002 10:20 PM
It can look clean but still be stopped up .Had that happen to me one day out in the trails.Went o the truck and blew out the filter and it worked for the rest of the day.
AdamScramblr400 Jan 29, 2002 10:29 PM
I checked the filter, It looked black, but pretty clean.
CED Jan 30, 2002 08:48 AM
You might check your reeds also.Just a thought.
Thor Jan 30, 2002 09:17 AM
What is the original color of the air filter supposed to be?
Run the engine without the filter once, if performance returns to normal replace the filter?
Did you play with the airscrew adjustment? If you did return the screw to it's normal position.
Could your choke be stuck?
Is your carburetor boot crack free?
Is the clamp around the carb tight?
Are the reed cage mounting bolts tight?
Could you have a plugged pilot jet?
Bogs are usually caused by a lean running condition.
Good luck[img]i/expressions/face-icon-small-wink.gif[/img]
AdamScramblr400 Jan 30, 2002 06:58 PM
I haven't touched the airscrew on purpose, but I might have accidentaly hit it. I have a UNI filter, and It is supposed to be yellow. I'm gonna put some engine degreaser on it right now. And see if that helps.
I think I'm going to buy a Filtercharger and waterrepelland outerware. I always have to take the airbox out, and It looks to cluttered under the seat. I don't ride in mud that often, but when I do, I'll just put the airbox back on. Do you think this is a good Idea? I'm fixing to put on a new post about it.
© 2026 MH Sub I, LLC dba Internet Brands
