Torque specs for primary clutch cover bolts
Old Feb 2, 2002 | 07:49 AM
Glen's Avatar
Does anybody know the torque specs for the six primary clutch cover bolts for a Sportsman 335? Thanks -Glen
Old Feb 2, 2002 | 09:46 AM
GE4x4's Avatar
The inner or outer cover. The outer cover there is no torque spec. Just put on the RTV silicone and tighten the screws. Also make sure you put the cover gasket flat edge out.
Old Feb 2, 2002 | 10:08 AM
Glen's Avatar
I'm talking about the the three legged inner cover on the primary clutch itself that goes over the primary spring. I have the torque specs for the center bolt, but I need the torque spec for the six outer bolts. Thanks, -Glen
Old Feb 2, 2002 | 10:17 AM
powerslider's Avatar
90 inch lbs. is the cover bolt torque spec from shop manual.
GE4x4's Avatar
The torque for the 6 boltsis 90in.lbs. to get ft.lbs multiply it by .0833.
Old Feb 2, 2002 | 10:29 AM
Glen's Avatar
Thanks for the info. I need to buy a service manual. -Glen
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
toonces
Aug 13, 2015 01:48 PM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
