COOLANT LOSS ON THE SP700??
Has anyone experienced any coolant loss on the SP700? I realize that when the machine is new you will have to top off the coolant level once or twice as the machine purges itself of air. After 360 miles, I find myself topping off the fluid after almost every ride. The last time the coolant level was down to the word polaris on the recovery tank. Below the minimum mark. The fan seems to be working properly and I have not found any leaks at all. Where the h-- is it going? Any help would be appreciated. It does not seem to be over heating either.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Farmr123 is correct. Most of them seem to leak around the black plastic waterpump cover. Mine leaked and I just added some Permatex to the stock o-ring and that solved my problems. Mine would only leak when I would really rev up the motor creating pressure on the water pump cover.
Originally posted by: Biggator
It can also be from a faulty water pump seal allowing coolant to enter the crank case. Unfortunately I have experienced this.
Ecellent question Lonewolf. My tech first did a compression check. If there would have been a problem with th bolts/head gasket it would have shown at the test. As there was no problem there he addressed the water pump seal.
jrooker6
Apr 23, 2016 07:36 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Sw00p
Sep 24, 2015 02:50 PM
