Time to slime the new tires
Old Apr 7, 2002 | 04:47 PM
FearSys's Avatar
Well, I bought Dirt Devils for my Scrambler and so far I have been EXTREMELY disappointed. I have had more leaks and holes in them than I did in the stock Titan 489's. I went out and bought slime for them today and was wondering who else uses it out there and what you think about it? Hopefully it will help. I am getting sick of having flats every time I get it out of the garage.
Old Apr 7, 2002 | 06:11 PM
modquad's Avatar
Are these tires on aluminum or steel rims? Did you buy them mounted, or do it yourself. Just wondering, I heard (don't know if it's fact or not) that the slime type products can be corrosive to aluminum.
Ken Thompson
Old Apr 7, 2002 | 07:02 PM
FearSys's Avatar
Aluminum, Professionally mounted.
Old Apr 7, 2002 | 09:54 PM
guardog's Avatar
The slime will make your tires wobble at high speeds. You will feel it in the handlebars over 50mph. The slime does work, but I would not want to sacrifice the handling
Old Apr 7, 2002 | 10:43 PM
ScramberShadow's Avatar
I got a set of DD on the front of my bike and I havent had a blessed problem with them yet! I ride where there is alot of sharp rocks, sticks, and no-see-ums and they go through it all with out a blemmish. On the other hand those stock 489's....each one had atleast 5 plugs in them and they were forever going flat! You did get 6 ply right?
Old Apr 7, 2002 | 11:53 PM
modquad's Avatar
You may have some porosity in the metal....or maybe just a bad valve-stem. Mix up some soapy water and wet down the tire/wheel. Where there's bubbles building, there's trouble. Cheap and effective.
Ken
Old Apr 8, 2002 | 01:51 PM
HondaMarshal2's Avatar
Don't do it!!! I put it in my tires and it made the tires out of balance at high speeds. I ended up taking the tires off and cleaning out the slime. WHAT A MESS!!! If you don't want to go fast than the slime will stop punctures. My .02 cents
Old Apr 8, 2002 | 03:59 PM
2000SCRMBLRMAN's Avatar
So thats what the deal is. I thought I had something bent. I used slime in one of my rear tires to fix a slow leak. Now that I think about it, that's around the time I first notced to 50+mph shake. I am betting that is it. I will be pulling the tire and cleaning that sh@t out of there, and fixing the original problem the right way.
Thanks guys!!
Old Apr 8, 2002 | 05:35 PM
Billyclub's Avatar
Cabela's has a $30. patch and pump kit that works great. Helped a friend out of a bind last week and these plugs are the ones the mechanics at the garage install in you're vehicles tires when they have a hole. I'm sure they have thier limitations in the size of hole they will plug but nonetheless it's very compact and I carry it in the underseat compartment on my Sportsman. Looks like a grey tube with end black end caps that open up.
Old Apr 8, 2002 | 10:46 PM
Elrancho's Avatar
Gah those bloody co2 tire kits. There are 12v bike pumps available that weigh a pound and fit in your hand, besides being cheaper than the c02 inflators these also fit in many 'ute' trunks. Combined with plugs of choice it's almost as good as a spare tire.
