let me get this stright
Old Aug 23, 2002 | 10:51 PM
danger's Avatar
when you order the cv joint the bering in the hub does not come with it?
and where do i get the bering {not bushing} for the stering shaft i went to parts land and they just show stock stuff what can i do to make it next to indestructable or at least tougherthis right front paws been thru hell twice any help would be apereciated
danger 2000 sportsman 500
Old Aug 24, 2002 | 07:41 AM
500DUSE's Avatar
Try gorilla(check the spelling)axal.com
Old Aug 24, 2002 | 09:58 AM
Farmr123's Avatar
As far as I know, the CV joint comes by itself.
Try www.gorilla-axle.com for CV joints, boots, and the like. Lifetime warranty on their stuff.
For the lifetime replacement steering stem bushing, check out www.rittercycle.com or www.hpd.com for those.
Good luck (hope I spelled all that right)
Farmr
Old Aug 24, 2002 | 05:13 PM
danger's Avatar
where can i get the solid brass brake pads and how about the berings in the hub
Old Aug 24, 2002 | 09:05 PM
Farmr123's Avatar
www.boxbrakes.com or www.boxbrake.com for the brakes.
As for the hub bearings, you can get those 'off the shelf' at any auto parts store. Just get the # off the old ones, or take it in with you.
Just as a bit of trivia, the taper roller bearings in the hub are the exact same thing as the pickup guage wheel on an OMC 596 baler, down to the number stamped on the bearing itself.
Farmr
Old Aug 25, 2002 | 03:39 PM
danger's Avatar
that link id a dead link or something farmr123 could you check it again thanks
Old Aug 25, 2002 | 09:49 PM
Farmr123's Avatar
Let's try this again:
www.rittercycle.com
www.hpd-inc.com
I double checked this time.
Couldn't get www.boxbrakes.com to work here, either. I wonder if they still are in business?
The Polaris 'severe duty' pads are far better than the standard as far as pad life, though. Maybe not quite the stopping power (but close) but last far longer.
Farmr
Old Aug 25, 2002 | 10:48 PM
danger's Avatar
the bering in the hub had no # stamped on it and im having a problem find ing it on line
Old Aug 25, 2002 | 11:16 PM
Farmr123's Avatar
Well, for what it is worth, my 1999 Xplorer 400 uses these Polaris part numbers:
Axle shaft bearing (2 per side) Polaris # 3554509
Bearing cup (race) for above Polaris # 355407
Hub bearings:
Polaris # 3554506 for the bearing
" # 3554507 cup for above
Old Aug 25, 2002 | 11:21 PM
danger's Avatar
wow that was quick
