2002 trailblazer oil injector
Old Aug 25, 2002 | 10:22 AM
curb's Avatar
Can i adjust the choke and throttle on the 2002 trailblazer took off the oil injector put block off kit on it real hard to start. the oil injector cable got cut would that do any thing to it. PLEASE if anybody has taken the injector off there (2002 Traiblazer) PLEASE HELP [img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Old Aug 25, 2002 | 11:12 AM
2manytoys's Avatar
Why did you take the oil injection off?It does not give you more power!The only benefit of doing this is not having to worry about the injection going out, but most 2 strokes have this system and it is not a common thing for them to go out. Pre mixing oil and gas will foul out plug alot easier.You will get more build up on the piston cuz it cant burn all the oil going into the head.Oil injection gives you a certain amount of oil at every throttle position.Premix gives the same amount no matter what.Going on trails at slow speeds will foul the plug.I guess it is a give and take situation.Trust polaris!They have had this system in thier quads for over 15 yrs.It is practicly fool proof.
Old Aug 25, 2002 | 11:25 AM
curb's Avatar
The injector is off all ready tank is to the cable to the injector was cut not putting it back on. the thing is hard to start changed plug runs rough can the float be stuck? will not idle. not running right. if any body has done this there 2002 trailblazer help. does the electronic throttle play a role in this or is somthing wrong with the carb any sugg.
Old Aug 25, 2002 | 11:33 AM
2manytoys's Avatar
When you took the oil line off did you plug the hole where the plug went?This will suck air and make it run real rough and not idle.
Old Aug 25, 2002 | 11:58 AM
curb's Avatar
YES I DID USED GASKET MATERIAL SILCONE ON THE BLOCK OFF PLATE. PLUGGED THE OIL LINE THAT WENT TO CARB. TOOK CARB OFF EVERYTHING SEEMS FINE THERE REALLY STUMPED
95wolv
Sep 27, 2024 12:00 PM
atvcollector
Sep 8, 2015 05:11 PM
chewy78
Sep 8, 2015 10:37 AM
byronman
Sep 6, 2015 06:34 PM
