Lighting SP 700
Old Sep 4, 2002 | 11:40 PM
valleyrat's Avatar
I'm trying to find out if anyone has any info on upgrading the 55watt high beam on a 2002 SP 700 from the 55 watt to a 100+ watt bulb.
I've already fix it so the three lights come on at the same time for the high beam. The recommended #1213/H4 does not fit the wiring harness on my SP 700.
Any suggestions will be appreciated.
Thanks,
Valleyrat
Old Sep 5, 2002 | 07:22 PM
floodrunner's Avatar
Rat, you’re asking for trouble putting a bulb with that much wattage in the pod light. It generates far more heat than stock and weakens the lens assembly. Ask me how I know.
Old Sep 5, 2002 | 10:01 PM
valleyrat's Avatar
Tell me all about it Floodrunner, please. I did this same setup on my Explorer 400 and it worked fine until I sold it a month ago.
Valleyrat
Old Sep 5, 2002 | 11:56 PM
BLAZIN325TrailTank's Avatar
If you put a higher watt bulb in there it generaters more heat, possibly causing damage to plastic and the light asemmbly. I seen this happen on a couple different quads and a car.
Old Sep 6, 2002 | 12:37 AM
Creepster's Avatar
Stop messing with little lights and mount a monster millions light on the thing. [img]i/expressions/face-icon-small-cool.gif[/img]
Old Sep 6, 2002 | 02:17 AM
SurferSam's Avatar
If you absolutely gotta have it, I believe it is a 9004 series bulb. Rocky Mountain ATV or Dennis Kirk's has'em.
Old Sep 6, 2002 | 02:54 AM
dougiedoo's Avatar
i don't know about bulb replacement... but i have info on electrical changes that will allow all three lights to be on in high beam. i haven't done this yet... it requires a few parts(radio shack) and a little electrical skill... if you are interested?
Old Sep 6, 2002 | 03:15 AM
Creepster's Avatar
If you want all three lights on , try link at bottom.
20 bucks gets you parts and instructions.
Three head light kit
Old Sep 6, 2002 | 03:38 AM
dougiedoo's Avatar
yeah, for 28.00 after shipping! i checked, or spend $5 at radio shack and do it yourself! if you need detailed instructions, it may be better to get that kit, just a thought!
Old Sep 7, 2002 | 08:56 AM
upnorthunter's Avatar
You can make the light modifaction yourself for about 5 dollars tops. All you need is a couple of diodes and some connectors. It works great too.
