torq specs
Old Sep 5, 2002 | 01:08 PM
BLAZIN325TrailTank's Avatar
What are the torq specs for the little outside bolts and the big center bolt on the outside clutch plate?
I have a 00 Trailboss 325
Old Sep 5, 2002 | 01:34 PM
modquad's Avatar
The drive clutch retaining bolt is 40 ft. lbs.
The drive clutch cover plate bolts= 90 in lbs.
The driven clutch retaining bolt=17 ft. lbs.
Threw that last one in just in case. I would also suggest a bit of blue loctite on the threads of them all.
Ken
Old Sep 5, 2002 | 11:32 PM
<< The drive clutch retaining bolt is 40 ft. lbs.
Ken
Which one is the first one(big one in center of clutch cover plate) when you take the belt cover off? driven clutch retainting bolt or drive clutch retainting bolt ????
Old Sep 6, 2002 | 01:30 AM
modquad's Avatar
Sorry man, the 40 ft lbs is the center single bolt on the front clutch. The 90inch lbs is for the six front cover bolts. The 17 ft lbs is for the center bolt on the rear (driven) clutch.
Hope this helps.
Ken
Old Sep 8, 2002 | 10:43 PM
Thanks MODQUAD for the torq specs.
raman8tor
Sep 20, 2015 07:35 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
toonces
Aug 21, 2015 01:19 PM
