Oil
Old Oct 8, 2002 | 10:05 PM
LY's Avatar
LY
Default Oil
Know the price of the Polaris brand oil before you buy any other brand, including Mobil 1. Around here Mobil 1 is more expensive than the Polaris brand. I only use Polaris brand fluids, because even if it does cost a little more you use so little of it a couple times a year that I don't see where it is worth taking a chance using something else no matter how good Mobil 1 is.
Old Oct 9, 2002 | 06:50 PM
hudonl's Avatar
Default Oil
hey guys im up in canada shell oil has a ow40 full synthetic about 4.60 a quart
mobile 1 is hard to get up here and they want your left arm with every purchase
good riding boys
Old Oct 9, 2002 | 06:56 PM
brent87LT1's Avatar
Default Oil
$4.60 Canadian? That's pretty cheap for full synthetic.
Old Oct 9, 2002 | 08:35 PM
hudonl's Avatar
Default Oil
P. S i forgot to mention that i have to buy it by the case but i dont mind because i have an 01 exploration 425 which takes 5.5 quarts per oil change the only big expense on that bike i also by an after market filter for 9.00 ea rather then 16.50 ea at the dealer keep on riding
Old Oct 10, 2002 | 01:28 AM
  #15
spacollie's Avatar
Default Oil
A long story made short, oil is oil if you replace it often. Syn. or not it dosen,t really matter. Some lubricants can stand greater heat but like I said, change it often and even cooking oil can stand the abuses. Spend your money on filters and change your oil more often as opposed to better oil. OIL IS OIL!!!!
Old Oct 10, 2002 | 10:17 AM
  #16
hudonl's Avatar
Default Oil
im sorry spacollie i cant agree with that one... oil is a technical issue heat ranges grades performances breakdown of oils when i read up on it i deciced to let the shell oil company compare the specs and make a recommendation specs are important more in some brands of machines then others and polaris is one of the ones you have to watch ... but i do agree on your thought about oil filters a good brand is important keep on riding
