Throttle Chop Jetting Test
Old Oct 30, 2002 | 09:37 AM
scramblazer400's Avatar
Default Throttle Chop Jetting Test
I have my own opinion of what this is but I am wondering
what the procedure is
I assume this is a throttle response test used to check for low end
mixture problems.
My Guess
Eng at operating temp,with a clean spark plug ,from idle,quickly crack the throttle until you get past
the lag/hesitation without letting it rev high enough to clear the plug.Repeat several times and check spark plug
to see if you are lean or rich- make adjustments as nec.
What do you think
Tom
Old Oct 30, 2002 | 10:37 AM
Surveyor's Avatar
Gaff had one of the best descriptions I've read in a long while in a past post... it is the next to the last post or the 6th one..
it may be worth a read.."Still haven't got the jetting right"
hope this helps..
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
mtdewmn
Jan 19, 2017 12:13 PM
manuelrivera
Aug 8, 2015 04:34 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
