SCRAMBLER KEY STICKIN ON AND QUICK FIX?
Old Nov 11, 2002 | 08:43 PM
rodman922's Avatar
Default SCRAMBLER KEY STICKIN ON AND QUICK FIX?
my key on my 02 500 sticks sometimes and keeps the starter engageing.any thing i can spray in the key area to fix it.because the dealer i bought it from su#ks at warranty work "midwest polaris"
rodman
Old Nov 11, 2002 | 10:51 PM
jmrpage's Avatar
hello
mine did the same thing. i took it apart and cleaned all the contacts and coated the inside with a water proof grease and now it works fine . hope this helps....
Old Nov 12, 2002 | 03:33 AM
ScottyO's Avatar
If you are using the rubber protected key it sometimes makes the starter stay engaged.
The rubber is not trimmed the right length on some of the 2002 keys causing this problem.
You can compare them to a key from a 2003 and see the difference. Try trimming about a
1/2 of inch off of it this has worked on all the ones We have seen.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Rooky
Sep 9, 2015 03:16 AM
