Polaris Plow attachment (Backordered)
Old Dec 11, 2002 | 10:43 PM
tjschmi1's Avatar
Default Polaris Plow attachment (Backordered)
Purchased a new Sp 700, two weeks ago. I love it. Great ride, plenty of power. The only problem is, I have the plow, put the attachment is backordered. Everytime I speak with my dealer, they tell me a different due date. Called Polaris twice, and each time they have told me a different delivery date also. You would think if x number of plows are manufactured, that x number of attachments would also be manufactured. Anyone else in the same situation??
Old Dec 12, 2002 | 11:09 PM
Cheezhead's Avatar
Do you know who makes Their plow you prob get one aftermarket I just put one on my Sportsman 500
Kevin
Old Dec 13, 2002 | 12:47 AM
Creepster's Avatar
I ordered mine in Sept. figuring on a backorder. Got it early Novemeber. Was worth the wait. Great system. beats the aftermarket ones hands down.
Old Dec 13, 2002 | 12:53 PM
yoopermike's Avatar
it seems to me that just about everything ordered for polaris gets backordered unless the dealer happens to have it on the shelf[img]i/expressions/face-icon-small-sad.gif[/img]
Old Dec 13, 2002 | 12:56 PM
CrispyCritter's Avatar
Tell me about it. Took me 3 Months to get a Starter. Now you would think that would be in stock since they build bikes everyday.
Just my 0.02 cents
Mark
Old Dec 13, 2002 | 04:24 PM
StevieD's Avatar
yup. took me a month and a half to get a steering stem, handle bars, and a new floorboard...
its pretty sad
Old Nov 1, 2003 | 12:52 AM
02Polaris700's Avatar
HELP!
Does anyone here have the Polaris Sportsman Deluxe frame plow system? If yes can you explain in detail on how the front attaches to the ATV ? possibly send me a pic?
When I ordered the blade and frame I reluctantly did not read the part about needing a winch mount plate.
TIA!
Old Nov 1, 2003 | 07:40 PM
Creepster's Avatar
You need the mounting plate. then it's real easy. No mounting plate and you'll never beable to mount it.
Old Nov 2, 2003 | 12:59 PM
upnort's Avatar
I have never had anything backordered from Polaris, everything has been here in 2 days. As for installing I found the directions that came with mine quite easy to follow and took about an hour. They have 2 different mounts 1 for the GEN IV and the IV+ is a bit different. The differances I saw were tube length and the front bracket. The IV has a bracket that mounts th the outside front frame with 4 bolts and the IV+ has a bracket that mounts up above the frame. I use the winch for lift and mine works great.
Old Nov 2, 2003 | 03:04 PM
98cobra's Avatar
Get the glacier plow system easiest to use by far!
