SP700 4WD Question
Old Jan 14, 2003 | 11:41 PM
sprtsmnfan's Avatar
Default SP700 4WD Question
Other SP700 owners, when in 2WD and pealing out, or on ice, do your front wheels still provide some pull? I was turning around on a gravel road about two weeks ago, in 2WD, and decided give 'er the nuts and whip the a$$-end around when the fronts bit and damn near threw me off my bike. It only happens when I really jump on it. It did it again when I was riding on a frozen creek near my house the other day too. I took it in and it did the same thing at the shop. With me present my dealer called Polaris about this and they said it was normal and that it had to do with the 700's new 4WD system. Has anyone else had this problem?
Old Jan 15, 2003 | 02:31 AM
MOUNTAINEERRIDER's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img]YES WITH THE NEW SETUP IT WILL KICK IN WHEN REAR WHEELS ARE SPINNING FAST.CAUTION....IT COULD JERK FRONT DIFFERENTAL OUT.BEST TO KEEP SWITCH ON WHEN ON ON SLIPPERY TERRAIN.
Old Jan 15, 2003 | 03:56 AM
Munzzzzzzz's Avatar
I've never had it happen to me, but I know someone who had it happen to him... he was doing donuts on ice. I was too, but I chose to keep it in 4WD so I didn't have to worry about it locking in on accident. Still did donuts nicely. [img]i/expressions/face-icon-small-smile.gif[/img]
I read about this somewhere else (either another thread here or on another board), and someone said they called up Polaris, and were told that the 700 creates so much torque it can throw the ATV into 4WD on its own if it's spinning fast enough. I don't know enough about it to be able to confirm that this is possible, but if Polaris says it is and this many people are having it happen, I believe it. Be careful, though... I've read (though never seen first-hand) that people have actually broken their front axles doing this. Not sure if Polaris covers that under warranty or not. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 15, 2003 | 07:28 AM
elroy2's Avatar
It can happen on any of the Polaris four wheel drive machines. Not just the SP700. Their are some things that could possibly be done to help the situation but, it is in the "nature of the beast". You may never get rid of it completely.
Old Jan 15, 2003 | 02:02 PM
sprtsmnfan's Avatar
Dang, not exactly what wanted in a in/out 4WD machine. Thanks for the info though.
Old Jan 15, 2003 | 11:00 PM
Bill35's Avatar
Mine did it the other day when it was real cold riding in the snow but not to long. After I stoped a backed up a few times it stoped.I think it was asting funny because it was so cold....
Old Jan 16, 2003 | 09:45 PM
sp7oo's Avatar
i have about 450 miles on sp700 and this has happened to me when it was cold . when the front diff oil is cold it tends to hang up in 4 wheel drive. i have found that by running the switch in awd mode most of the time ,that when you do really want 2wd it works fine because the oil is hot and thinner allowing the diff clutch to work properly this has worked every time for me and i am riding in -9deg f temperatures. heat up that front diff and you will find that it works much better.[img]i/expressions/face-icon-small-smile.gif[/img]
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
