First oil change..question??
Thanks guys..i got the 400ex filter..did the swap myself today..glad i did..there was quite a bit of metal on the drain plug! Not a whole lot, but enough to be glad i changed my oil!
Thanks again!
Oh..whats the hex screw on the oil filter cover for??
Thanks again!
It could be for a oil pressure test. I don't know, but it sounds good.
By the way, did my oil change tonight and was very easy. I didn't have much metal, but some. Also put on a 13 tooth sprocket, K&N filter, and my shock covers.
#16
Scotts88, Give that puppy the bone, it wants it!! Go ahead and give her hell Scotts88 just dont hold it wide open for very long. Enjoy the power and handling as it only gets better the faster you go!!
#17
Hey Scotts88 I forgot to ask you a question about your predator.. Are you living on or out of your predator? Didn't you just get your predator yesterday? You already have 5 hours on it!!! Remember the predator needs it beauty rest also.
#18
I got the bike on wed...put a little over an hour on it since then..did the oil change today and drove it on and off for till I got about 5hrs total on it...[img]i/expressions/face-icon-small-wink.gif[/img] So your saying i can start putting the hammer down??
#20
I also did the one hour change ... I did drain the ps4 oil and go to silkalene for the break in I don't think synthetic is the answer for brake in..also the plug or tap fitting is used if you leave the drain plug out over night or while working on a drained oil system, it is a place to prime the oil pump for when it is run dry... I have to say I have nothing but good to say so far on this machine....
