Fuel Mixture Screw
Old Jun 14, 2003 | 01:42 AM
Flagg's Avatar
Default Fuel Mixture Screw
Turns out my raw fuel smell was a leak at the "reblock" plastic part between the carb and the motor, was warped and needed to be replaced. Dealer said they only found it by sheer luck. It happened to backfire while sitting there.
Runs quite a bit better now!! lmao
Flagg
Old Jun 15, 2003 | 01:03 AM
kblazk's Avatar
could this be why my 03 sportsman 500 does not start unless i give it a little gas? (choking only makes it start harder) And the only time i can start it without the throttle is about 5 minutes after i shut it off. It will just sit there and crank unless i just barely push the throttle in, (warm idle is set at 1200 rpm)
Any thoughs if this is it, can i get to the mixture screw without drilling all over the place?
cdoren
Aug 16, 2015 11:22 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
