RCR pipe on 330 trailboss
Old Feb 6, 2003 | 04:24 PM
sliderm's Avatar
Default RCR pipe on 330 trailboss
Can I put a RCR pipe (topend,midrange or lowend) on my 330 TB, while using my stock silencer ? Will I still have the 8 hp I'am supposed to gain ? Will it be louder ? Has anyone tried this ? What's the difference between a plain clutch spring and a stock spring ? AND LAST BUT NOT LEAST: WILL I REALY FEEL THE DIFFERENCE? Thanks for your advice to a french " quadeur " who cannot get any information on all the stuff you guys get in the States.
1 new 330
and a load of motobikes
Old Feb 6, 2003 | 05:41 PM
2manytoys's Avatar
You will notice a huge difference with the pipe. I dont know if RCR makes a pipe for it yet but if you talk to rick ritter he might be able to make one. It will be louder unless you use a quiter silencer or if your stock one fits. I am using a stock 400 silencer with my pipe and it sounds real good.
Old Feb 9, 2003 | 12:57 PM
MossMan84's Avatar
THE THREE TYPES OF PIPES YOU SPOKE OF (TOP, MID, LOW) ARE FOR 2 STROKES. A FOUR STROKE PIPE IS JUST A PIPE. (sorry, caps lock was on) The shape of the 2 stroke pipe determines where the power is distributed. (rpm range) You won't get nearly as much from a full aftermarket pipe on a 4 stroke as you will a 2 stroke.
Old Feb 10, 2003 | 11:23 AM
sliderm's Avatar
Thanks for the data on the pipes, some deception I thought it was going to be easy!
Anyway, could you tell me what your modifications did for your 325 and if your muffler is louder than stock.
Old Feb 10, 2003 | 02:27 PM
MossMan84's Avatar
The mods I did pepped it up quite a bit, and yes, the muffler is quite a bit louder thatn stock, but not overwhelming. Aaen carries a weld on spark arrestor that is supposed to tone it down quite a bit. All of the mods you see listed in my sig were barely $200 total. Check out Aaen Performace
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
Myronh
Sep 8, 2015 11:27 AM
