Where can I get more discs for my Predator silencer?
Old Feb 9, 2003 | 01:27 AM
Rob4092's Avatar
Default Where can I get more discs for my Predator silencer?
I put a "Pure Polaris" silencer on both of my new Predators.
There are eight discs on it right now (the silencer came with eight discs installed out of the box), but I want to add two more to make it "thoatier" and louder. Where can I get additional discs?
Thanks!
Old Feb 9, 2003 | 01:32 AM
powerslider's Avatar
Rocky mountain atv has them.
Old Feb 9, 2003 | 03:36 AM
Rob4092's Avatar
Kewl!
Do you know how much and part #'s?
Thanks!
Old Feb 9, 2003 | 08:57 AM
A six pack will run you 17.05 WB-06922 www.rockymountainatv.com
Old Feb 9, 2003 | 12:36 PM
Rob4092's Avatar
Thanks for the info!
How many do you run in your Predator?
Old Feb 9, 2003 | 12:45 PM
Six will be the number I use, that is what's been recommended so far. The header pipes are very large stock and you need backpressure to make it run well so that's where I would start. The Superbike Shop is doing R&D now, their site has some good info.
Old Feb 9, 2003 | 01:43 PM
Rob4092's Avatar
It came stock with 8 discs installed.
Does that seem right, or am I simply counting them incorrectly as it is kinda hard to see while they are mounted.
Old Feb 9, 2003 | 04:30 PM
Yes they come with 8 but experiment with it, try 6,7 see which set up seems to work the best. Depending on your elevation you may have to change the jetting also especially if you do ANY airbox mods or change to a K&N filter.
Old Feb 9, 2003 | 05:45 PM
Rob4092's Avatar
OK, I just removed them and there are a total of nine discs on it.
The airbox is stock.
The jetting is stock.
I ride at seal level in Mexico where it can get very hot and humid.
Is my stock jetting going to be "OK" with the above set up?
Old Feb 9, 2003 | 05:50 PM
Yes your jetting should be ok.....
shimanok2
Jan 29, 2016 07:37 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
