scrambler carb on trailblazer
Old Mar 1, 2003 | 08:18 AM
elroy2's Avatar
Default scrambler carb on trailblazer
there is a big dead spot off the throttle
Do you mean off idle? If so, good luck getting rid of it. I'm pretty sure I know what its about and nothing you can do about it without some big $$$$. If I'm right, I'll bet talonhawk doesn't have one hardly at all. I can say I've made mine all but disappear but I have to run my idle to 1/4 throttle on the verge of dangerously lean. If anyone were to ride mine without knowing how to ride it, they would blow it up in less than 15 minutes. Me, I have ridden this way for just over a year and have no intentions of tearing it down anytime soon. It runs good, just got to know how to ride it.
I did a search and found what Mike told you. I sure miss Mike. Don't see him around hardly anymore. We don't care if you ride red.
Old Mar 1, 2003 | 10:27 AM
talonhawk's Avatar
The flatslide carb is the way to go. I tried the 38 TMX Mikuni on my 99 TB
first. ( recommended by Hotseat Performance back then ) I never did get
that carb dialed in right. It had a flat spot off idle so after screwing around
with it for over a year I changed to the 35 PWK keihin ( thanks to Darrell at HPD )
Its a wonderful carb. I did have a very small hesitation of idle but I've fixed that
by changing the pilot jetting. BINGO!!!
Just received my lightened flywheel ( 1.8 lbs removed ) from HPD and I'm pretty
sure that I will get a Comet primary clutch this Spring. Thanks to Modquad for
that NEW information!
Old Mar 1, 2003 | 11:34 AM
x_scrambler3's Avatar
I have run a 34m carb on my 95 TB from a 98 Scarmbler 400 an all I did was to change the jet in it. I am still running the carb now on it an have no dead spot off the bottom end. I know had to go down alot on the jet size from what was in it but now with the Reedcage convertion had to go back up.
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
