SP 700 Fuel Leak
Old Mar 2, 2003 | 08:30 PM
catch2255's Avatar
Default SP 700 Fuel Leak
HAve an 03 700 and only put about 3 hours on it so far. Fuel started leaking under the machine. I did some research and found it leaking where the fuel exits the tank. I removed the nipples and wrapped teflone tape around the threads and reinstalled it. Has anyone else had this problem and if so how did you do to fix it. I have not had a chance to test yet.
Old Mar 3, 2003 | 01:41 PM
VeryPicky's Avatar
I had the same problem with mine and my dealer used the same fix that you did. Mine has not leaked since. You should be all right.
randymack
Aug 24, 2015 05:47 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
Unzzy66
Jul 11, 2015 10:01 PM
