Pred paddle tire question
Old Mar 12, 2003 | 09:46 AM
SANDMAN430's Avatar
Default Pred paddle tire question
i forgot about those turbo paddles my brother has those, and they do work good , they seem heavy also but they are tuff, although i did notice some chunks missing after our last ride. he has both geckos and turbos and the sad truth is he still wishes he had got haulers. i've rode a predator with 20" 9 paddle and they worked great that is what i would recommend.
Old Mar 12, 2003 | 10:56 AM
still12nv's Avatar
i have run sand skate 2 they where ok my favorate is the skat trak v blade 8 paddle best hook up i ever had.
they dont chip off like the skate or the shark and they lasted me really long
Old Mar 12, 2003 | 01:28 PM
TireFryer30th's Avatar
I ran the geckos on my Pred. for one weekend...they seemed to work okay, but I am gonna switch to either a reg. straight paddle, or a v-groove style...the geckos just seemed very heavy.
I am gonna run them on my Banshee tho...it should be making more than enough power to turn them.
TireFryer
Old Mar 12, 2003 | 11:43 PM
pred007's Avatar
Iwent with the cheap dune runners from Rocky Mountain ATV. They seem to work O.K.
I have edge v's on my banshee and they are a real good all around tire. they are a little more agressive than the SSII's (even with 6-7 pounds)but let the air down a little and they hook great for dragging. Both of the tires i got are 22" 10's so i can swap em if i dont like the way the straights work out on the pred. Now.. Before i got my Pred in November, I talked to a Factory guy that was Cruisin around with several predators. He had two identical bikes and he said that he ran 10 paddle 10" on one and 8 paddle 10" on the other (20" tall on both) and he said that the Predator had the nads to pull the 10 paddles and in fact worked "quite a bit better" than the 8's.
It really depends on what your trying to accomplish. Drags- 22x10x10 / all around and slide- SSII's or edge. really want to slide with alot less hill or drag ability? sand sharks!
I'd still reccomend going to a 22" cause you can inflate or deflate to conditions better than 20's and you get more floatation.
Old Mar 18, 2003 | 12:45 AM
  #15
MFGrizzly660's Avatar
Hey I ended up getting the Sand Skate II's. Does anybody know what pressure i should run on them?? It says not to go past 30 but that seems like a lot. Any info?
Thanks
Old Mar 18, 2003 | 10:33 PM
  #16
vilnrk's Avatar
i would try 5psi
turbo bobby
Old Mar 18, 2003 | 11:32 PM
  #17
thanks vilnrk,
uh should i run different pressures for different types of sand? I mean wet sand and dry sand, or does it make a difference? Thanks
Old Mar 18, 2003 | 11:36 PM
  #18
vilnrk's Avatar
nah...with the ssII it should really make much difference. they get good traction anyhow
turbo bobby
Old Mar 19, 2003 | 12:08 AM
  #19
thanks a lot Vilnrk. do you have the SSII's?
Old Mar 19, 2003 | 08:36 AM
  #20
vilnrk's Avatar
no, i used to have a set a long time ago, now i have padla brat 9 paddles
turbo bobby
