Lightweight 4-stroke engine?
Old Mar 31, 2003 | 05:09 PM
CED's Avatar
CED
Default Lightweight 4-stroke engine?
I seen there was a sportsman 500 motor on e-bay.Later.
Old Mar 31, 2003 | 10:11 PM
Bill35's Avatar
Hi dbeck I see your from Missesota there was a company called cayuna that was from Minnesota they made some nice high rpm motors...
Old Mar 31, 2003 | 10:16 PM
dbeck's Avatar
Bill,
Yes, they were made on the Cayuna Iron Range and were put in Scorpion snowmobiles. They are now sold under the 2SI brand name.
Old Mar 31, 2003 | 10:48 PM
Bill35's Avatar
Go to there web-site http://www.2si.com/index.htm they have some very nice looking 2 and 4 stroke motors I have a old Cayuna motor on a old eagle ultralight 20+ years old and runs great.
Old Mar 31, 2003 | 11:01 PM
  #15
dbeck's Avatar
Bill,
The motors run around $5,500.00 I'm hoping to find an alternative engine that I could pick up for much less. Some of the guys are using BMW or Moto Guzzi motorcycle engines.
Old Mar 31, 2003 | 11:18 PM
  #16
Polaridoo's Avatar
What about the VW bug engine they sawed in half? Forgot the name of the company doing it, but I think they even retro'd it with dual magnetos. Not sure if it put out 50 hp though. Maybe with a few mods and big bore cylinders it could get close.
Old Apr 1, 2003 | 09:47 AM
  #17
pudjumper's Avatar
CRF450 weights only 66 lbs and claimed hp is around the 55 mark.
Old Apr 1, 2003 | 01:05 PM
  #18
dbeck's Avatar
The CRF450 is a 4-stroke? What is that a Honda motorcycle engine? Does it have a built in transmission?
Old Apr 1, 2003 | 01:18 PM
  #19
NovaKaw650's Avatar
dbeck - a wrecking yard in New Brunswick has a used Kawasaki Prairie 650 engine for sale. 2 cylinders and no gearbox. 43 HP at the crank stock. Don't know the weight. $1000 Can.
Old Apr 1, 2003 | 03:01 PM
  #20
LEP7MM's Avatar
the CRF450 is the 4-Stroke motocross bike of Honda's. Yes it does have a gearbox. You're looking for an auto so you can mount your gear reduction box right to the shaft, right? Or doesn't the powerchute require a gear reduction?
