spring tension on the secondary??
Old Apr 19, 2003 | 09:04 PM
TWEEKER's Avatar
Default spring tension on the secondary??
[img]i/expressions/face-icon-small-confused.gif[/img]I read on of the topics here and it said to turn the helix a 1/3 turn but when you do this it is very tight is this right if i put the setting at 2-2 the ramps on the helix are about inbetween the buttons so do you go just to the first setting or one more turn of the helix?
Old Apr 19, 2003 | 09:41 PM
modquad's Avatar
It should be a total of about 1/3 turn counter clockwise.
Old Apr 19, 2003 | 10:05 PM
TWEEKER's Avatar
ok so if the helix ramps are in between the buttons a 1/3 turn to the buttons isn't right ?? you go past to the next set????? and one more thing my trailblazer is ported piped milled head and 34mm with stock clutching set up in the 2-2 and white spring in primary when i nail the gas it will come over backwards has great bottom end but when you hold it wide open the midrange don't pull the engine sounds it's bogging down it is still picking up speed but not nothing to great if you hold it there for a little bit the rpms start to come up and fast, then it will pull again really hard is my secondary spring to soft or what please help!!!! thanks
Old Apr 20, 2003 | 10:19 AM
scramblered's Avatar
tweeker,you're secondary spring is too stiff,i didn't run such belt pressure on my modded 400,poor backshifting and no full shif out,
those quad doesn't need so much LBS in the secondary...
you can have a great first ride but as soon the clutch get to their peak operating temp,it slip,and you're loosing big deal in the power tranfer.
Old Apr 20, 2003 | 07:02 PM
TWEEKER's Avatar
ok so where is a good starting point for the spring location and your saying less pressure will shift and back shift better and have less slippage ?
Old Apr 20, 2003 | 08:15 PM
that it,i suggest to try 1-2 instead,less spring tension will give less belt slippage and better bachshifting (throttle response of the clutch)
but upshifting will decrease in the top end.
Old Apr 20, 2003 | 11:04 PM
Bubba297's Avatar
Not to contradict what scramblered is saying, but I dont like to go any less than 1-1 on the secondary spring. Also tweeker, if you hear the engine "bogging down" but your not losing speed, sounds like you need a different helix. If you still are running the factory helix, it is pulling the motor RPM's down on the top end. You need a split with the lower second number to keep the RPM's up. Just my opinion,Bubba
Old Apr 21, 2003 | 02:11 PM
yes,like bubba297 is telling,it is a another good issue,tell us what helix is in?
Old Apr 22, 2003 | 12:31 AM
TWEEKER's Avatar
yes it's stock and thanks to the both for all the great info what do you think i should try for a helix or spring i see that the violet from hpd is comon they're about a hour away from me the reason i am having this dilema is that i have made my own pipe and it works great it's the clutching i wish i could test it against another pipe to see where it compares don't want to buy one just to see there kinda spendy to do what i want to do if you understand thanks again
shimanok2
Jan 29, 2016 07:37 PM
raman8tor
Sep 20, 2015 07:35 AM
bvolks
Sep 13, 2015 12:57 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
