Need help bearings
Old Apr 28, 2003 | 04:04 PM
cwdancer's Avatar
Default Need help bearings
My Wife's 325 2x4 front wheel has some side to side play in it. I have tried tighentening the outer bearing nut but it is tight already. I think it may be the inner bearing bad. I am ording (2) new bearings and seals. Do I need to replace the wheel spacer also?? I have never taken off a polaris front hub. Can some one let me know the proper way to remove it. Do you need a puller to get the hub off or does it just slide off once the outer bearing nut is off?? Can the spindles get damage easily from a bad bearing??
Thank You
Jim E :
Old Apr 28, 2003 | 04:35 PM
NCScrambler's Avatar
No special tools needed. It should just come right off. What year is it by the way?
Old Apr 28, 2003 | 05:46 PM
cwdancer's Avatar
It is a 2000 325 2x4 magnum
Old Apr 28, 2003 | 05:52 PM
Look here for the parts breakdown on your model, it should help you a little .
Old Apr 28, 2003 | 05:58 PM
cwdancer's Avatar
Thanks fo all the information I just got back from picking up all the parts I need I am just worried that the hub isn't going to come off easy.
Old Apr 29, 2003 | 11:58 AM
SurferSam's Avatar
If your bearings are worn badly, be sure to check your bearing races in the strut housing for wear, grooves, etc. And yes, badly worn bearings might damage the spindle, too. Good Luck. If you need any more help, post back here.
BTW, don't overtorque the spindle nut. You can wear out the hub innards prematurely.
SurferSam
Old Apr 29, 2003 | 02:47 PM
lancems007's Avatar
The hub will pull right off. No need to worry!
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
