How many grease points on an 02 scrambler?
Old May 4, 2003 | 08:37 PM
tkslma's Avatar
Default How many grease points on an 02 scrambler?
i found 7, did i get them all?
Old May 4, 2003 | 09:16 PM
BigBadScrambler's Avatar
(2) ball joints, (2) fornt brake calipers, (1) steering post, (2) a-arm, (2) u-joint on half shafts, (1) rear axel, (2) swing arm bushings. That is 12 so far. This is for my 2000 scram but I am sure that it is the same for the 2002. I dont know if your tie rod ends have zerks or not, mine dont. Also check the fornt prop shaft. I think it may have one for both u-joints on it. Hope this helps. Later
Old May 4, 2003 | 11:15 PM
NCScrambler's Avatar
Yep 12, but I got 2 at the base of the front struts for the wheel bearings. There are not any zerks for the front brake calpiers, only bleed screws. See here. Here is where the ones on the front struts are located. #14 here.
Old May 5, 2003 | 12:26 AM
Yes, NC is right, Sorry, just finished working a 10 hour shift[img]i/expressions/face-icon-small-disgusted.gif[/img] Dont know where my head is tonight[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 5, 2003 | 08:56 PM
scrambler420's Avatar
how many are on the 02 400 2x4?
Old Jun 5, 2003 | 10:35 PM
Should be 10. All the ones stated above except the U-joints
Customer Service #1
May 15, 2020 08:46 AM
bigred20653
Oct 2, 2015 10:05 AM
1000gade
Sep 9, 2015 03:35 PM
Elkaholic
Sep 6, 2015 02:44 PM
