cutting fenders
I am planning on cutting the fenders on my trailblazer 400 and was woundering if there is any tricks and what kind of tools do i need.
chris |
cutting fenders
i have cut my fenders and i used some tin snipes and a file. You could use a router. As for were to cut it is up to you. Oh and mark it out with a washable marker first to have a line to cut by.
cutting fenders
A dremel tool with a spiral cutting bit works well. get one of the 'downward cut' ones, and run it at the slowest speed the tool has. The slow speed will eliminate melting, and the downward cut bit will put the 'burr' from the cut towards the underneath of the fender. Yes, and mark the cut before you start.
Farmr |
cutting fenders
I cut them with a dremel. Used high speed cut off wheels. Went Through plenty of them tho. The one thing i do like about those is that they heat the plastic up and leave a nice smooth edge. I made a template first with masking tape, use a waz pencil to draw what u want first. Tin Snips were ok but it took forever. Have some sand paper handy too, it will help out with the rougher edges.
cutting fenders
speakin of plastic anyone know where to get some aftermarket plastic for a scrambler cause wanting to get a custom paint job on it and the old stuff is pretty scratched up
