AAEN TOP END PIPE
Old May 8, 2003 | 07:33 PM
Jwb's Avatar
Jwb
Default AAEN TOP END PIPE
Hey anyone have a top end pipe if so any sugestions because I just ordered one and was woundering what fender work and jetting needs to be done also how does this baby run????
Old May 8, 2003 | 07:51 PM
mojave300ex's Avatar
NcScrambler has a AAEN pipe, he's the man to talk to.
Old May 8, 2003 | 08:07 PM
NCScrambler's Avatar
No fender work needed, It fits nicely. Mine did anyway. I like the pipe, it seems to have a good broad powerband. I can't really tell you about the jetting, I done alot of mods at one time including changing the carb, so... You will probably just have to increase your main jet size 1 or 2 sizes up. I would call Aaen back and ask them, they have always told me almost spot on what my jetting should be. Did you also get clutching with the pipe? It is pretty necessary to get full benefit of the pipe. I would also recommend the HPD airbox when you get the money to do it. You will tell a big difference with just the pipe, but the air box makes a big one too.
Old May 8, 2003 | 08:13 PM
Jwb's Avatar
Jwb
Yes I ordered the clutch kit but the bad thing is that I will only be needing the main drive spring since I have a TEAM PERFORMANCE roller clutch wich is bad ***!!! I have a k&n filter how much did the air box help???
Old May 8, 2003 | 08:18 PM
Cool, I would like to have one of those myself. The spring change will do fine for the pipe. Is it a clamp on K&N or does it fit inside the airbox?
Old May 8, 2003 | 08:22 PM
Jwb's Avatar
Jwb
K&N but it fits inside the stock airbox also if you ever want one of those roller clutches my dad is a dealer and will give you a great price he also is a SLP and AAEN dealer if ever need anything.
Old May 8, 2003 | 08:32 PM
Cool, check your PM. I really like the HPD box and I think it adds alot of power and is alot easire than removing the whole airbox to do any carb adjustment. I definately recommend it.
Old May 8, 2003 | 11:03 PM
Bubba297's Avatar
Darn JWB, i have an Aaen top end pipe on e-bay right now. If I would have only known. It has been used very little. If you know anyone else that might want it let me know.
Old May 10, 2003 | 06:22 PM
scramblered's Avatar
with a top end pipe you'll need to spin faster the engine so check for a properly matched clutch kit,also it mean that most HP will be at top end power,less torque but more peaky than usual pipes.
with stock carb,better to start at 290 main.
Old May 10, 2003 | 07:57 PM
modquad's Avatar
I'll second that, Bubba's pipe is like new! [img]i/expressions/face-icon-small-happy.gif[/img] Most all of the earlier generation pipes were peaky like Scramblered stated. Not til you get into the ATV8 pipe did you have power throughout the throttle travel.
JWB, what secondary clutch setup did you have prior to the TEAM unit? Are you using the Kevlar belt? Getting ready to intstall the TEAM unit with the Comet primary. Gonna try to run both setups at some timed drags soon. Gonna be interesting to see the differences. Also, are you running the newer clutch cover with the larger cooling outlet? Makes a big difference.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
