03 Scrambler Gearing Mod
Old May 10, 2003 | 01:07 PM
ProXPredator's Avatar
Default 03 Scrambler Gearing Mod
Is there any way to change the gearing on the 03 Scramblers? Just wondering, cause isn't it shaft drive in the front, chain in the rear? Also, Someone posted on here about putting a Sportsman tranny in the Scrambler......Anyone know if this? That would be great if the Scrambler had a low range also, but I don't know if it would hold together with the speed of the Scrambler. Let me know please!
Old May 10, 2003 | 03:41 PM
Farmr123's Avatar
Sportsman tranny will NOT fit in a Scrambler. The Sportsman tranny is designed for use with rear IRS shaft drive. The Scrambler is chain drive rear, shaft to the front.
However, an Xplorer tranny might. It will be a little heavier, due to having low range, but as far as I know, it will fit. Best to do some heavy-duty measuring before you try just to be safe, though.
Farmr
Old May 10, 2003 | 04:41 PM
BigBadScrambler's Avatar
Changing the tranny has been done. A guy on ebay just sold one that he put a low range tranny in Here As far as changing the gearing, I think you can go one size different on the rear sprocket. Anything more than that and it will screw up the 4x4
Old May 10, 2003 | 07:52 PM
FTZLT250r's Avatar
It really comes down to how often you use your 4wd. I only put it in 4wd when I had to. I had 14/34 gearing, and the difference between the front didn't matter. I ran it that way with no problems at all.
Old May 10, 2003 | 09:13 PM
425Xpedition's Avatar
Been running the low range tranny for since last summer.The low range tranny will bolt right in. The fun part is making the shifter work right. When I did mine I wanted it to look it came from the factory. But it was not that hard to do. The airbox has to changed also. The added weight of the tranny is less than 10 pounds.
I use to run a 12 tooth front and 38 rear before the tranny swap. I was running 25" tall tires with this gearing and no problems with the four wheel drive.
Old May 10, 2003 | 09:23 PM
425, what tranny did you put in it?
Old May 11, 2003 | 04:10 PM
The tranny came out of 2001 Xplorer 400.
Old May 12, 2003 | 10:58 AM
4464's Avatar
try looking into the heelclicker clutch kit, I have one on my '02 scrambler and it gets going right off idle. it acts like a granny gear. many polaris owners who have installed the kits hardly ever use low range anymore, that's how good they work and easy to install.
Old May 13, 2003 | 06:37 PM
NITROMAN500's Avatar
COULD YOU SHOW ME A WEBSITE WHERE I MIGHT BE ABLE TO FIND THIS HEELCLICKER CLUTCH KIT?
Old May 15, 2003 | 02:36 PM
4464's Avatar
Go to www.heelclicker.com and they will be coming out with a 2-speed secondary soon!
'02 scrambler 500 X, dg xcellerator exhaust system,
K&N fliter, HPD airbox & jet kit, heelclicker clutch kit,
H/L water temp. gauge, radlites, shock covers, HSP
chain tensioner, rear rack, super cooler, rear hitch,
12 volt outlet, rear skid plate.
