Trail Blazer tranny probolem
Old May 12, 2003 | 03:41 PM
ToomeyBanshee1's Avatar
Default Trail Blazer tranny probolem
Lately, whenever the transmission is engaged in forward, without revving the engine, it kinda grinds in till the lever actually engages. I have fresh oil in the tranny. What could be causing this?
Old May 12, 2003 | 06:00 PM
NCScrambler's Avatar
Your idle could be too high or you may need to adjust the linkage a little bit.
Old May 12, 2003 | 07:54 PM
The idle is fine. How do I adjust the linkage?
Old May 12, 2003 | 08:57 PM
Look at the rods leading from the shifter box to the tranny, there should be some threads and nuts, loosen the nuts and turn the rods until it locks positive into gear, then tighten the nuts back and you should be done. Of course this is assuming that it is only an adjustment problem and not internal.
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
Logan Collins
Sep 5, 2015 08:03 PM
JakeXBL
Sep 5, 2015 01:08 PM
Canamaniac!
Sep 4, 2015 06:44 PM
